Coupler problem
davidstrains
1,014
Stafford, VA
I am having a bit of a problem keeping a set of new Bachmann F7 A&B units coupled. This is the N Gauge Spectrum set. I have not converted it to MT's yet as I am working on the track and wiring right now. I am running a test train with 8 40' cars and a caboose The A unit disengages at random points around the layout. I was looking for a bump or a depression that might be causing some uneven stress but that does not seem to be the case.
When the units disconnect the coupler on the B unit is in a "raised" position and does not go down until I push it down. After a couple of minutes it goes back up. (spring problem?)
Is there anything short of changing out the couplers that I can do to keep the train connected at least until I have the time to install the MT's?
Thanks.
Clerk
1,678
Esparto, California
David.
I to baught a pair of F7's A & B units. They keep coming uncoupled at random. I got so discusted I changed all the couplers to MT and haven't had any problem since.:D
If you want to keep running them, you may consider dropping everything and consentrate on changing those couplers.
Whenever I buy a engine or car, If it isn't equiped with Mt couplers, I change them immediately. A few years ago when I first started my first layout, everything had repido couplers. I got so fed up that I changed to MT and have had very little trouble since then.
By the way I work in "N" scale. The best.
davidstrains
1,014
Stafford, VA
Hi Clerk
Originally posted by Clerk
............I changed all the couplers to MT and haven't had any problem since.:D
What M-T coupler did you use. I like that option, it just wasn't a good time since I am trying to wire the layout now. But if it isn't too much of a project I may just take a break and do the conversion so I can run a test train or two. I have a pair of Atlas GP-7s that are MT equipped and they work fine, as do the Kato Mike's. I should probably convert my 2-8-0s while I am at it. Do it once and get it out of the way.
Clerk
1,678
Esparto, California
David.
I used the 1015/16 Coupler. Actually, a long time ago I baught a package of MT coupler kits (a package that has about 200 different parts for various couplers) and can assemble different types as needed. I haven't seen this kit in quite a while. I came across it in a model store up in Washington state. I am pretty sure the 1015/16 will work.
davidstrains
1,014
Stafford, VA
Dick,
Thanks for the information, I am off to the LHS tomorrow to pick up a couple sets of the 1015/1016 couplers. I guess I should also check the MT website for the couplers for the Consolidation tender conversion. I might as well do them all at one time and save the hassle later.
thanks again. I'll let you know how it turns out.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
David:
You could make a start by just converting the inside ends of the units. Is the B a dummy? If it is, you then have a converter car.
There might be a flash or spring problem in the rapido coupler. I don't know how the spectrum couplings work -- I'm thinking of what they used 20 years ago.
davidstrains
1,014
Stafford, VA
Hi David,
In the Spectrum set both the A and B units are powered. I have made up 2 converter cars out of a couple of older box cars that I have had for years. I bought a package of the trucks and couplers while I was out in Seattle and converted 10 cars with that package. I still have 40 more cars to go, but as I said before I am still trying to finish the wiring. The purpose of running the F7 set was to put a couple of trains on the track to check out both the trackwork and the wiring progress in DC mode.
I'll check for flash but I don't remember seeing any. I do think it is the spring on the B unit. The coupler when disconnected from the A points up at an angle. I have tried to force it down and it will stay for a while and then disconnect again.
Tonight I just wired the couplers together with a single strand of wire that I took out of a 2" length of stranded #18. Keeps them together forever.:D :D
wendell
43
farmington NH
Dave if the ab units are comming uncoupled can you install a draw bar between the two units I did this on two atlas gp 30's Idon't know if you can on the spectrum. the couplers on the gp 30 is held in with a clip. Wendell
eightyeightfan1
Now I'm AMP'd
Torrington, Ct.
Sounds like N scale.....I remember the MT coupler number.
Now working in Ho I have found that though the Bachman E-Z Mate coupler connects with the KD's, pulling long trains they tend to part. Solution:Junk the E-Z Mates, replace with KD. No problems since.
