Construction of the Fall Creek RR
Discussion in 'Getting Started' started by Rusty Stumps, Feb 21, 2003.
  1. Rusty Stumps
    Rusty Stumps Member
    I've posted some pictures on my website of the construction techniques I've used building the framework for my railroad.
    This differs from the standad 1x4 constuction greatly. Stop by: and browse the pages.
  2. jwmurrayjr
    jwmurrayjr Member
    Nice work!
    You could be a boat builder. How are the legs working out?
    The "contours" of my layout are built of 1/2" blue styrofoam on edge (mostly). It was very easy to cut and shape and like you say almost "mess-less".
    The sub-roadbed is also 1/2" blue styrofoam using the "cookie-cutter" method for grades and elevation variations. This has worked very well.
    Please keep us posted.
  3. dwyaneward
    dwyaneward New Member
    great Ideal on the beams. Check out the rest of your site I really like the workstation article. Just what I need.
    Check out your progress as well, Like that long truss bridge.
  4. Rusty Stumps
    Rusty Stumps Member
    Well, thanks fellas! Now as I'm working on the layout I've also moved in a new direction!!!:eek:
    A number of you know I do resin castings. I've just been approached by a kit manufacture to do metal and resin castings in bulk. So I'm moving into spin casting.
    Like my layout, I'm not being conventional. Not too sure I want to publish just what I'm doing, don't want to give any competitors a "leg up" but I may be posting something on that in the future.
    The commercial spin casters run from 10 to 20 grand which is way out of my league but I've come up with a different way to enter the field and if it works who knows I may start on a whole new career. Let's see, that would be #15 I think! (grin)
  5. Russ Bellinis
    Russ Bellinis Active Member
    It looks good! Did you run into any problems getting the drywall screw to hold in the sides of the plywood? The screws hold well going through accross the plys, but I would think they would tend to strip going into the edges.
  6. Rusty Stumps
    Rusty Stumps Member
    Russ, not too many problems. But then again, the screws are just there to hold till the glue sets. I used 2" long drywall screws and pre-drilled the holes. Also, the triangles in the corners add a lot to the strength of the frames.
    When I build the next section frame, which will be at a right angle to the main, I will use a slightly different approach. I want to experiment with 1/4 tempered Masonite as the web piece and I will use 3/4" end blocks for attachment to the cross piece.
    I never do anything the easy way! Life in particular!:D I'm now experimenting with spin casting of white metal and resin parts. I'm converting a medical centrifuge for this purpose!:rolleyes:
