Computer Generated HO Guard Rails
Discussion in 'Scratchin' & Bashin'' started by Fred_M, Nov 20, 2003.
  1. Fred_M
    Fred_M Guest
    I need some guard rails for my overpass but the LHS didn't have any I liked. So being the tight wad I am I'm going to build them from a computer and a white paperclip. I yanked out a ribbon cable and cut it in strips two wires wide.
  2. Fred_M
    Fred_M Guest
    I then cut posts from a white paperclip and glued them on with CA jel.
  3. Fred_M
    Fred_M Guest
    I then drilled holes and glued in the guard rail. Maybe later I'll weather them. Total time, two guard rails... 20 min.
  4. csxnscale
    csxnscale Member
    Thanks dash10 for sharing this idea.
    They look great, wonder what I can do in N-scale.
  5. Mrs.Mac
    Mrs.Mac Member
    I like it!! Thanks for the tip.:D
    Mrs. Mac
  6. Fred_M
    Fred_M Guest
    The new ATA 100/133 IDE cables are 1/2 the size of what I used and should work for N if your not a rivet counter. Posts from smaller wire. I finally found a good use for a computer...DASH:)
  7. McFortner
    McFortner Member
    What can I say but that looks Fincredible! (F'n incredible) ;) :D :D :cool:
    That is an idea I'm going to have to remember. Thanks for sharing.
