Cold Solder - as advertised on TV
Discussion in 'FAQs' started by dwight77, Dec 12, 2004.
  1. dwight77
    dwight77 Member
    I asked this question in N Gauge but no one has responded yet so I thought I would try here. I have seen a "cold solder" tool advertised on TV. It sells for $19.95. It is battery operated but shows that it only gets hot when actually soldering. When you are finished with the solder job, you can touch the end of the tool and it is cool. I was wondering if anyone has tried this tool when soldering track together. If it works, it would seem to make it a lot easier and possibly not have to worry about getting the track too hot and melting plastic ties etc. I just wanted to know if this was a viable tool?......or just another TV infomercial come on.
  2. hminky
    hminky Member
    I have one. I like it for trackwork. The resistance soldering is really neat. It works well with Code 100 HO track, so should work well with N scale. The ties don't melt :thumb: . Also makes track feeders easier.
    Hope that helps:D
  3. dwight77
    dwight77 Member
    Thanks Harold. Sounds like it might be worth a try.
  4. SAL Comet
    SAL Comet Member
  5. dwight77
    dwight77 Member
    Thanks Scott: quite informative. Looks promising. What part of N W Georgia are in. I have a daughter in Dahlonega.
  6. Charles Mark
    Charles Mark Member
    Our Costco had these for sale approximately $17 as I recall.
  7. SAL Comet
    SAL Comet Member
    dwight, I'm in Taylorsville, in Bartow Co. About 50 mi. west of Dahlonega
  8. docsnavely
    docsnavely Member
    My mom tried getting one for Christmas for me, but their website said they were on back order, and all of the auto parts stores were sold out. Instead I get a dremel. Not too bad of a switch if I do say so!:D
  9. rrs517
    rrs517 New Member
    Save Your Money
    I bought a Cold Heat resistance soldering iron from Radio Shack Friday 12-31 and returned it today 1-2. It is a toy. There is NO WAY you can get 700 solders (would you believe maybe 20) out of a set of 4 AA batteries. It works pretty good for about 12 joints soldering #24 AWG to Code 100 rail - after that you need new batteries. Worse yet is that the tip appears to be made out of a fragile material that resembles the material used in powdered ferrite cores and it is VERY fragile. After about 20 solder joints and $5 worth of AA cells my tip was shot. Went back to my 100/140 Watt iron and did the rest - faster - better - cheaper. Joints take under 2 sec with no melted ties. Use a good liquid flux applied to a CLEAN rail, heat the gun well, and apply solder and in 2 sec you have a beautiful joint. Save your money - there is a reason that resistance soldering systems start around $250.
  10. cyb0rg
    cyb0rg New Member
    I come from a long line of infomercial junkies. My mom has QVC on speed dial. I've purchased more than my fair share of stuff online, home shopping networks, and commercials. I've learned that there are two things you should avoid buying:
    Tools and exercise equipment.
    George Foreman it. Had it for years, still works like a champ. I could name several things in just this room that I bought from TV. Every tool I've ever bought either A) Got returned within a week or B) Never worked like it was supposed to. Buy Craftsman. If it breaks, they replace it for free. Forever. You don't even need a reciept.
  11. dwight77
    dwight77 Member
    Hi Richard(rrs517):
    Thanks for the info on your experience. Did you read the link that Scott (SAL Comet) had above? He had good luck wiring leds. Maybe the size of the application makes a big difference, wire versus track. Sounds like it may be time to let this one ride a bit, or come up with an economical tip replacement and the use of rechargeable batteries.
  12. ezdays
    ezdays Out AZ way
    This sounds like a great idea, but I wondered what the tip was made of the heat and cool that quickly. Could be some ceramic product, but none the less, even with rechargable batteries, you could be changing them out in no time flat.
  13. shaygetz
    shaygetz Active Member
    I got one for Christmas. Quite frankly, my jury is still out. With a little practice it might do well but I agree with Richard, there's just nothing that beats a good hot iron, a clean joint and flux. I will keep trying for now. With two small children, the peace of mind alone is worth it.
  14. trainking49
    trainking49 New Member
    cold heat
    Thanks for the input guys, sounds like it might be worth a try.
  15. Blake
    Blake Member
    This has answered the question for me. I wondered how long those batteries would last. Being that this tool is a resistance soldering iron, I would guess the tip is made of carbon. I have an American Beauty resistance soldering unit and built my own single probe tool from a cheap 25 watt cigarette lighter soldering iron (paid $6). For the probe I use a welding rod that is used for cutting. It is very soft and fragile.
