Discussion in 'Scratchin' & Bashin'' started by jjwalsh, Oct 11, 2004.
  1. jjwalsh
    jjwalsh New Member
    converting mdc climax to On30,wondering if someone has ideas,re-gearing
    climax for better performance and to quiet it down.
    Thanks in advance.
  2. Ray Marinaccio
    Ray Marinaccio Active Member
    Welcome to The Gauge John.
    I have an MDC boxcab that uses the same drive. I replaced the primary gearbox with a belt drive, which quieted it down and reduced the overall top speed.
    I removed the gearbox, made a new driveshaft that connected the worm shafts of the two trucks together using an Athearn SW 7 driveshaft with a pulley from an old tape deck pressed over the slotted coupling. An Athearn drive belt was used to run from the pulley to the motor.
  3. jjwalsh
    jjwalsh New Member
    Thanks for the info,will give it a try.
