Chemical transfer facility
Discussion in 'Scratchin' & Bashin'' started by railBuilderdhd, May 22, 2008.
  1. Here I'm attempting to build some sort of chemical or fuel facility that could be found on the side of a track some place. Not doing any scratch building before I’m not sure where I’m going to go with this build but I got all the tubing from the Plastruct sale and I thought I would see what I can come up with without any studying of prototypes. I’m posting here to just get a feel of what others think so I would like to hear your comments.
  2. Russ Bellinis
    Russ Bellinis Active Member
    I suspect the upstate New York and Southern Ontario guys could help you the best. The area around Niagara Falls is known for Chemical plants.
  3. TrainNut
    TrainNut Ditat Deus
    It looks simple but to the point. Is there a difference between the four pictures other than the tanker in the first two and not in the last two?:confused: I flipped back forth several times but that is the only difference I found.:confused:
    If there is no difference, you may want to edit your post to remove the 2 superflous pictures (makes it easier on the dial uppers!).
  4. RonP
    RonP Member of the WMRC
    please size your pictures so it isn't so difficult to view them. Majority of all people have resolutions of 1024X768 but if you are covering all your bases 800X600 would fit this forum perfectly
  5. Ralph
    Ralph's for fun!
    I've been working on a fuel loading facility myself without much in the way of proto photos to help. I echo TrainNut's thoughts. It effectively conveys the idea to me. Neat use of the Plastruct tubing, by the way. My only suggestion might be to maybe provide some supports for those long pipes leading to the center tank.
