Change "Registered User" text to custom text
Discussion in 'FAQs' started by urbancowboy, May 16, 2004.
  1. urbancowboy
    urbancowboy New Member
    How do I change the text that appears underneath my username in all posts that I do on the forum? I had changed it before but then i had to re-register again and now I'm not sure how to change it again.
  2. jon-monon
    jon-monon Active Member
    Welcome back! You should find it in your profile under "user CP" linked above.
  3. urbancowboy
    Hello jon-monon,
    Thanks for the reply, I checked out the "profile" section under UserCP and still could not find any area to change the text, "Registered User" to something else.
    I also looked at setting an avatar but the only thing I see is the option "Do not use an avatar" with a radio button right beside it.
  4. N Gauger
    N Gauger 1:20.3 Train Addict
    No, it isn't there - I reported it. :)
  5. RailRon
    RailRon Active Member
    Thanks Mikey - I've got the same problem.
    I'll keep going back to the UserCP/"Edit Avatar" section. One of these days the editing window for "Registered user" will be back. :rolleyes: :wave:
