Discussion in 'HO Scale Model Trains' started by Snizotch, Dec 20, 2006.
  1. Snizotch
    Snizotch New Member
    Some people have mentioned that you can glue your road bed and track down using silicone caulk. Any one have any ideas on how you can do this without getting caulk all over the ties? It seems like it would make a big mess out of the tracks.
  2. LongIslandTom
    LongIslandTom Member
    I think you have to remove the flextrack first, then apply a bead of the silicone caulking to the roadbed where you want to lay the track, spread it out just a little using a putty knife, then put the track down and hold it in place temporarily using pushpins. After the silicone sets, you can take off the pushpins and the flextrack should stay in place.
  3. 91rioja
    91rioja Member
    I use two types, white and clear. The white is all purpose for attaching anything. I use the clear under my track to attach to the roadbed. It goes on white, but dries clear. A little ballast over top, and you're done.
  4. MasonJar
    Use LATEX caulk too - it's paintable in case you get some where you don't want it, but don't notice until later... Don't ask how I know this... ;) hamr
  5. 91rioja
    91rioja Member
    Mason, I think we have all been there before. At least you used it on your layout; I used it around the door frame in the kitchen and wondered why no paint would stick. . . .
  6. Alan Bickley
    Alan Bickley Member
    I just use strips of double-sided carpet tape. When I have ballasted the track, it holds pretty well.
  7. Doc Holliday
    Doc Holliday Member
    I used white lates caulk, although I didn't entirely remove the track to do so. First I laid out the track on the cork roadbed exactly where I wanted it and pinned it down. I then lifted small sections one at a time about 1/2" high by raising the pins and applied a thin dab of caulk to the cork by first spreading it on a putty knife and then sliding it under the ties. I repeated about every 3" along the track. Push the track and pins back down until it sets. Worked great.
  8. jbaakko
    jbaakko Active Member
    I used Tan caulk, and spread it with a cheepo $.97 putty knife from home depot.
  9. kitsune
    kitsune Member
    Note you *can* use glue instead, but it generally takes longer to dry. You can do a lot of tracklaying or roadbedding binging with caulk.
  10. Snizotch
    Snizotch New Member
    Awesome. Good info, thanks everyone.
  11. Russ Bellinis
    Russ Bellinis Active Member
    One other advantage to using latex caulk is that it can fill in any "whoop dee dos" that might show up under the roadbed. If you use a cdx grade of plywood for a bench top instead of some of the more expensive grades, the latex caulk can be used to fill and smooth knot holes under the roadbed.
