Building My Layout - Sharing A Short History
Discussion in 'N / Z Scale Model Trains' started by atsf_arizona, Nov 14, 2003.
  1. atsf_arizona
    atsf_arizona Member
    Hi, all,
    As some of you know, for the past 15 months I've been working on a little 4' x 4' N scale layout, depicting (roughly) a couple of scenes from the early 1960's Santa Fe's Peavine Line branch off the transcontinental main from Ash Fork, Arizona to Phoenix, Arizona.
    Here's a little layout construction chronology. Just sharing it for general consumption by all:
    My railroad was made with Woodland Scenics risers on a two 2' x 4' plywood module bases.
    #1 (in the middle of the loop is my 1/10 size model of my N scale railroad I made prior to starting on the N scale railroad itself):
    #2 built up using foam insulation boards the scenery:
    #3: This is shot of the canyon 'Prieta Grade' module with WS plaster cloth laid down over the carved foam canyon wall. The plaster gave a base shell for the followon scenery paint, foam, etc. You *can* paint the foam directly using latex paint. In my case, I was using the WS earth color for my base and it wouldn't penetrate/hold on the naked foam, and therefore needed plaster foundation. WS Plaster cloth did give me a rocky ground base texture that I like:
    #4: This shot shows same module, looking across the canyon in the other direction. You can see that I used wadded up newspaper for part of the canyon wall below the track level here. You can also see that I was just stacking 1" and 2" foam insulation, gluing it using WS Foam Tack Glue, then carving it:
    #5 - then I put Sculptamold over everything to give it a good rock texture look:
    #6: This photo shows the plaster cloth down. I put Sculptamold
    over the plaster cloth to give it a more natural texture than the
    'cloth impregnated look' that the native Plaster Cloth had. Then
    I painted with WS earth color on everything, then painted on matte medium (i.e. WS Scenic Cement) as adhesive, then used WS ground foam sprinkled on for the ground texture. I'm amazed the WS ground foam looks so good my first time out, it's nearly impossible to make it look bad as long as you select appropriate colors. I used the WS roadbed.
    (No I'm not a walking Woodland Scenics advertisement. I just didn't have the time to figure out other alternatives that I'm sure many on this Forum
    will also tell you about - smile).
    #7: This shot shows a view of the 'Prieta Grade' module in natural sunlight, after I'd scenicked the canyon wall. I used a lot of 'earth' color WS foam to give it texture as a base, then lightly sprinkled on WS 'burnt grass' color foam. As I'm modeling Arizona, I don't use any deep greens of any sort (as Arizona brush is too dry to ever look like lush East Coast forests).
    The natural sunlight is what really brings out the model color photograph, by the way.
    #8: and to make a long story short, here's what it looks like today:
  2. Clerk
    Clerk Active Member
    That looks great John.
  3. Arlaghan
    Arlaghan Member
    Very Cool!
    Are those handles because it's designed to tuck away underneath a bed or something? Did you put wheels on the bottom?
  4. atsf_arizona
    atsf_arizona Member
    The handles are to allow easier handling of the module. (smile)
  5. Tyson Rayles
    Tyson Rayles Active Member
    That's really looking nice! :cool:
  6. Matthyro
    Matthyro Will always be re-membered
    Thanks for showing us how you built your layout John. Nicely done.
  7. NScale
    NScale Member
    Thanks for sharing. Looks great! :)
  8. jawatkins
    jawatkins Member
    Very, very nice work. I haven't used sculptamold yet, but I like how it works on your layout.
  9. cpNscale
    cpNscale Member
    How did you get 8 pictures added to a single post?
    BTW great looking job on the module
  10. atsf_arizona
    atsf_arizona Member
    Hi, cpNscale,
    In order to get multiple images in one post, you just have to know how to key in the write command syntax within your
    Go here, read what it says, even though it's for the Atlas Forum,
    the syntax used is the same for almost any chat room forum that we commonly use these days.
    Hope this helps!
    John Sing
    San Mateo, CA
  11. Cinnibar
    Cinnibar Member
    Peavine Line Branch
    For some reason I’m just nuts about small, compact layouts and yours is no exception. It is really shaping up nicely. Plus yours is the first time I have ever seen anyone use the W.S. risers and roadbed. Seems like they worked very well for you, you are indeed an excellent advertisement for W.S. products. I look forward to seeing your layout progress.:thumb:
  12. Tad
    Tad Member
  13. pttom
    pttom Member
    Really looks good..
