Bmann tender electrical pickup conversion
Discussion in 'N / Z Scale Model Trains' started by loggerhead, May 3, 2006.
  1. loggerhead
    loggerhead New Member
    Has anyone out there modified a Bachmann vanderbilt tender (like the ones that come w/ the 4-8-4) for electrical pick-up. I'd like to use one on my Bmann Light mountain. The MP vandy tender is too small, so this is about it other than a Con cor. Unfortunatly, the 4-8-2 needs the electrical pickup to run well. Any help would be appriciated.
  2. loggerhead
    tender pick up
    Anyone have some assistance they can give out there?
  3. eightyeightfan1
    eightyeightfan1 Now I'm AMP'd
    I've never done it. But, you might try installing those wipers you see on the bottom of lighted passenger cars.
  4. Ray Marinaccio
    Ray Marinaccio Active Member
  5. Randof
    Randof New Member
    Could someone direct me to a source for the electrical pickup wipers or entire truck assemblies? I seem to be having a problem finding them.
  6. Boilerman
    Boilerman Member
    I did my own using .010 brass shim stock purchased from an auto supply store.
    I cut the wipers and installed them on each of the 2 trucks making sure that each truck has the insulated side of the wheels all on the same side on each truck and then install the trucks so that each will be picking up the current from each rail.
    There is an article on the web on doing this to the Bachmann N-Scale Northern and that is were I got the idea.
    This a very easy conversion and makes this loco run super.
    Richmond Controls offers a kit to install electrical pick up contacts if you are not versed in working with the shim stock.
    I hope that this is of help, I will try and find the article.
  7. Boilerman
    Boilerman Member
