Blackadder's Imperator Titan Build
Blackadder
663
1,602
91
Psychotherapy..... all the while twiddling my thumbs and toes when I could be basket weaving.
Whew!
48 of these bad boys and they're only half done.
But finished enough to mount them on the corner bastions.
I just have to match them in threes to allow for minor discrepancies in size.
9,599
I would tie a fishing line to the highest point of the model up to the ceiling, that way it can tip over, just spin around. This may piss off your cat though, be warned.
12,462
Those pieces look like organ pipes. :)
She might "get a hang" out of it..! :animated:
Reactions: zathros
9,599
She might also get strung out!! ......In all honesty, with the work you have put into this model, I would just hate to see it fall over a break itself from it's own mass. I know another modeler that the same thing happen with a paper version of what you are doing, and it took a lot of fingers to put that beast back together. I do love cats though, mine have destroyed almost all the models, evenn knocking the lifeboat off of my 32" Lilla Weneda" model, to let the dog chew and crap it out on the lawn. The lifeboat really went though it. I mowed over it till it dissolved in the rain. An ignoble ending. :mooner:
Blackadder
663
1,602
91
Raison d'être:
The business end of the Emperor Titan is it's massive arm weapons.
For too long I have put off finishing up these bad boys and not realizing the primary purpose of lengthening the legs. The guns were hanging too low and interfering with the hip joints or so I thought. In actuality the thighs were just too short.
Now we can see the preparation for the gatling cannon mount device which is greatly modified from the original mount bracket.
I've only just started the second gun mount but I thought it would be best to show it in the beginning stage.
Blackadder
663
1,602
91
Thanks for the reply.
Multi-Barrel Weapon:
I'm trying to rationalize a multi-barrel weapon that looks like a gatling gun but does not rotate.
Something like this:
Let me know what you think.
I don't even know what kind of projectile this thing shoots but judging by the end of the barrels the shot is oval. I'm not going there. I draw the line at an oval shot.
I like the idea of a rotating chamber and I'll keep that but I also prefer the weapon mount disk over the bracket mount seen below:
The Bracket mount just looks too plain and ugly.
The top view looks Okay
All in all, not a bad day's work.
I just have to rationalize the barrels and the cylinder arrangement.
Blackadder
663
1,602
91
I like the picture and plan to incorporate many of it's features. I was recently apprised it is an energy weapon. And of course the scale is way off but the individual details are quite worthy.
Meanwhile:
I found some of my old images as well and decided to play around with one.
My old Photo Impact 13 program produced this in an hour or so:
Blackadder
663
1,602
91
Once again Serendipity Rears Its Ugly Head.
I began this Mega Blaster shortly after the Plasma Cannon but due to the conflict in scales I wasn't sure how large to make the arm weapons so I left it undone.
As I built the body and legs it became apparent that both weapons could be ridiculously too large or too small.
Originally I thought a meter tall (39 inches) would be a good height for an Emperor Titan but proportion wise as I built it I had to keep correcting the height.
At least four to six times at least. A month or so ago I increased the length of the thigh about 6.35 centimeters (2.5 inches). Hopefully for the last time.
The model now stands about 1,27 meters (50 inches) with still the spires on the bastions to go adding another six to eight inches.
I managed to make the drum training device which is a lot more business-like than the forked yoke bracket. that is seen on the original Joazzz2 creation.
A dry run assembly today with a side by side comparison of the Mega Blaster and the Plasm Blaster Cannons....
confirmed that the arm weapons are in a close scale to the rest of the Emperor Titan.
A final touch today is the forward muzzle plate with a stylized 40K skull embellishment to start off the fine detailing.
Blackadder
663
1,602
91
Serendipity Doo,
I found just what I was looking for; I love the internet.
What the doctor ordered. The rear assembly of a Mega blaster that can be adapted to my construct with a minimum of alteration.
Just assemble a couple of boxlike structures and attach the elevation drum gear.
Then somewhat faithfully copy the detail and we'll have the suitable energy producing end of the Helstrum Megablaster.
I even have some of the armour to replicate.
Ahhh! It;s Christmas.
Blackadder
663
1,602
91
Despite Appearances,
The clothes pins are on the rear of this piece.
The first 3 images are of the paper template I made to pattern the drum gear saddle.
(I just make names for these parts as I go.)
I made the pattern in full originally....
Although the pattern fit rather well I found making the pieces would be easier if I made them in two parts.
Paper seen here....
Than to make the styrene piece from the pattern in one whole piece.
The plastic pieces installed....
The result appears satisfactory.
Blackadder
663
1,602
91
Apples and Oranges:
Or
Is my face red?
A day or two ago I was apprised that the images I was using for my Hellstrom weapon were of a Chain Ammo weapon called a Mega Gatling cannon. :blush: (Why is there no blush emoji?)
In defence I rationalized that the overall basic counterbalance form is what I was looking for and not the actual details.
But in retrospect it is plain as day that the curved structure on the lower edge of the center section does readily show an ammo belt feed replete with 6 rounds and a bolt action loader.
The ammo box being the rear third section of this very heavy weapon. (The six PVC tubes alone weigh a couple of pounds .)
While both arm weapons at this point weigh 2 pounds each the front end moment of the Plasma Blaster is 4 ounces and 10 ounces for the Hellstorm Cannon.
Detail, details.....
Interestingly enough it is precisely what I was looking for when I first began this multi-barreled weapon I.E. a projectile firing weapon.
So now I have the option of both a 5 barreled energy weapon (redundant with the Plasma Cannon). A quick change Hellstorm Cannon and a six barrel Gatling gun.
10,005
I fully understand your frustration. I have dealt with similar issues when making models. The "DEVIL" is (indeed) in the details.
With that being said, you are doing a truly AMAZING job on this project!
As for a "Blush" emoji, there is one that is titled "OOPS" :OOPS:.
12,462
Oh boy, when that fellow is firing his guns, you might think it will trigger an earthquake! Incredible work, pal! :toast:
Blackadder
663
1,602
91
Gatling Blaster:
While I am in the process of making a HellStrom Cannon I figure it wouldn't hurt to build a Gatling Blaster quick change set of barrels as well.
That way I can have the option of either weapon with minimal trouble.
The first thing is to make the six Barrel mount cone.
Here we see the cone which is simply a disk of styrene about ten inches in diameter with a center eight inches in diameter removed.
I then took the two inch wide strip and made a cone about 4 inches wide so there are two layers of 0.020 styrene which should be strong enough once the cone is covered with reinforcing bitz of sheet styrene.
Once the glue is dried I have the rough form of the bell housing that is ready for detailing.
