Blackadder's Imperator Titan Build
Blackadder
663
1,602
91
Time To Take Stock.....
After a week hiatus I revived with new inspirations on how to proceed. The Lower sixth of the cannon assembly vexed me until I realized where my problem lay. It is pretty much what is found wrong with a majority of scratchbuilds; they are too square and straight sided. The lower rail needed some slight curvature to the sides and base.
https://i.imgur.com/q3M6lG9.jpg
Fortunately the material I am using has a taper for ease of extraction from the mould.
https://i.imgur.com/biPfc7S.jpg
Playing on that feature I came up with the correct angles to duplicate the artist's rendering.
https://i.imgur.com/10kf0vn.jpg
This will be more apparent in subsequent images.
9,592
Who could argue it? :)
Blackadder
663
1,602
91
I think I'll Have To Add Another Barrel:
Not much going on with the model these days. I've got 3/4 of a year working on these two guns and am nowhere near finished. For example today I spent reducing the bore of the five o'clock position barrel which gratifyingly finally looks right (to me).
https://i.imgur.com/FdGlpjo.jpg
I did a quick setup of the hull to take these pictures and have something posted before Christmas.
https://i.imgur.com/xGathUi.jpg
I made the barrels extra long so I could adjust the length with a minimum of refabricating
https://i.imgur.com/kko672F.jpg
it seems I must adjust them by a ninth
https://i.imgur.com/oHB0eGA.jpg
To match the picture and the Sunfury Annihilator Turbo Laser.
Have a Happy Holiday.
Blackadder
663
1,602
91
A Cog Disc
The more I build this thing the more I think these are actually revolving barrels. But they are energy weapons so what is the point???
Anyway my production schedule has been compromised by the Holiday Festivities I made time today to make the Cogged backing chamber for the barrels
You can see by the image below that it looks like the backing plate and the barrels rotate as a single piece
https://i.imgur.com/C5XZ2u6.jpg
Anyway the component is straight forward and simple to replicate thanks to the Waffle material; the Fluorescent Light Diffuser Panel.
https://i.imgur.com/fpkT8hb.jpg
9,592
A Cog Disc
I think you're absolutely right about the barrels revolving. It would also facilitate easier arming. The picture you posted shows a curve on the center truncated cone section which does seem to indicate the barrel spin. Good catch! :)
Sudsy
537
1,538
A Cog Disc
Point: rotating barrels look cool in a gattling way. Logic is sketchy beyond that. Greeble on steroids!
Which you are making look great by the way!
Blackadder
663
1,602
91
Eight into Five just don't go evenly;
Cogs that is. Yeah I know but that's what the image calls for. It was either eight or nine and there wasn't space for nine cogs. I could have done six but the spacing would have been too great. No matter how you slice it the revolving chamber just doesn't work. But you know I just don't care anymore. I'm tired of playing with these guns :D
https://i.imgur.com/M7Jc32J.jpg
Last night was the first time in three weeks I actually had time to work on this thing since New Years.
https://i.imgur.com/xMwHSlu.jpg
I've decided that the 5 barrels remain stationary and the cylinder revolves. Don't ask me how or why but dimmit that's the way it's gotta be.
https://i.imgur.com/qYlONTk.jpg
Now I've gotta adjust the barrel length and the support carriage.
https://i.imgur.com/mCUqsMZ.jpg
And get this show back on the road.
https://i.imgur.com/dOnd5s2.jpg
9,592
It's not like you're trying to make a working gun. It looks great! :)
Blackadder
663
1,602
91
Thanks for the replies,
Egad! I've forgotten how this thing goes together!
It's been six or so months since this Emperor Titan took a header (fortunately without sustaining much damage) and it was, at the time, inexpedient to reassemble the completed components. So this past week I've been trying to figure out HOW I BUILT THE D@MNED THING! All the body components interlock together without glue to facilitate assembly and disassembly (So I can add the interior detail when I get to it) but there are 20 to 30 major components and the sequence of how they are assembled has been trial and error. HA!
https://i.imgur.com/ErYsfTT.jpg
Anyway here is what it looked like before it toppled and we can go from there.
9,592
Freakin' awesome!! ;)
dr_tetrode
142
330
40
65
My goodness, having read through the whole thread, awesome! To see all the pieces come together, so far! Wow! I have enjoyed learning how you solve your engineering problems, it has been a delight to read. Thank you! and keep going!
Scott ;-)
Blackadder
663
1,602
91
A Crash Test Dummy:
Is building this Titan.
I wish I could blame this on the cat or something but instead I am making inroads into stupidity.
I was going to show the interior with the positioning plugs I have been working on for the past few days but instead here we see a pile of rubble which was the inner levels of the interior.
https://i.imgur.com/ZzEMFGN.jpg
Fortunately its not all as bad as it seems in spite of falling the same 5 feet again in much the same trajectory as the previous fall a couple of days ago although the computer chair did not intervene to soften the mishap this time so a few items actually did break this time.
As I type the glue is drying and most of the damage is repaired (I'm getting good at it by now)
Anyway, with hope, I'll be able to photograph the aligning plugs later today.
Blackadder
663
1,602
91
Quarter Galleries:
For lack of a better term; this is the area I'll be working on
https://i.imgur.com/gjLeebc.jpg
The images are pretty much self explanatory; I'll be framing out the "Quarter Galleries" with cut Florescent light panel waffle diffusers purchased at Home Depot.
https://i.imgur.com/rr4ohCP.jpg
The panels are made of very hard and brittle styrene plastic but are plenty durable for framing and is cheap compared to hobby shop styrene. About 4 feet long and about 2 feet wide metric users can do the math....;)
https://i.imgur.com/FrpJg0s.jpg
9,592
So I guess the "Crash" is being or has been remedied? :)
