Bachmann Spectrum 2-8-0 Question
Clerk
1,678
Esparto, California
Rory, I just clocked my 2 - 8 - 0 at 75 mph at max speed for just a short distance. I usualle run it batween 45 and 55 mph. I don't know why your's will not go faster unless something is binding.
billk
1,116
Marion, IA, USA
Clerk and KV are probably right. Just wanted to add that the max voltage put out by your power supply would come into the equation, too. So we should really be talking MPH at a given voltage level.
roryglasgow
1,223
Huntsville, TX USA
web.wt.net
Well, I suppose that it could be my power supply... It says that it puts out up to 13 volts at 400 milliamps. That doesn't sound to beefy on the amperage side... I'll try another power pack and see if it does any better...
billk
1,116
Marion, IA, USA
Just time how a train takes to travel a measured distance. Here's an example:
Measure off a distance of 100 (actual) inches, and measure the time it takes the train to cover that distance - say it takes 50 sec.
That means at the same speed it would travel 100 * 60/50 inches in a minute, and 100 * 60*60/50 = 7200 inches in an hour.
Then convert the 7200 inches to your scale, for N scale that would be 7200 * 160 = 1,152,200 inches per hour, which is about 18.2 miles per hour (1,152,000 / 12 inches per foot / 5280 feet per mile).
Converting all this to a magic formula:
N-Scale MPH = Distance traveled in real inches /
(0.11 * Seconds taken to travel that distance)
Clerk
1,678
Esparto, California
Here is a "N" Scale speed scale somebody worked up for me using a 36" yard stick
Seconds to travel 36"......... MPH
65................................................... 5
22 ...................................................15
13.....................................................25
9....................................................... 45
5........................................................60
4........................................................75
3.........................................................90
There may be somebody out there that will argue and break it down to milaseconds or some such thing but this is close enough for me.
MCL_RDG
851
S.E.PA.
And here all the...
...time I been using the "Looks a little too fast (conversely- little too slow) method" for whether my train crews (me) were observing the speed limits. ;)
Glad to hear you solved your prob rory.:)
I've also heard the reasoning for governing steam loco speed (as far as modeling goes) as 1 MPH per inch of diameter of the driving wheels. So that a 60" driver would deliver 60 MPH.
I still go by what looks right as far as the eye perceives.:eek:
Ramsey Electronics sells a "speed" detector radar kit that might be fun to build and use. The only thing is you'd have to hang a 6" dia X 8" can off a N, H-O (or whatever scale you model) police car parked behind some trees near/on your mainline ( chrome sunglasses and Smokey Bear hat not included!:( ).
Mark
:D :D :D
P.S. As a bumper sticker on a motorcycle I once read said, "Speed on brother- Hell ain't half filled"!
