Bachman 2-6-0 Mogul
Discussion in 'HO Scale Model Trains' started by crawford, Dec 3, 2006.
  1. crawford
    crawford New Member
    Would the Bachman 2-6-0 Mogul be a good train to start out with. Until I can afford something a little more exspencive. Its in the $60.00 dollar range thats about all I can afford. Also would this be suitable for 1930's-1940's logging. Thanks Crawford
  2. shaygetz
    shaygetz Active Member
    While near the end of its life, it would be a perfect shortline hauler and as a logger on the bayous and flatlands of the deep south. It wouldn't be nimble enough for northern logging though...but, alas, there's a prototype for just about anything if you look hard enough.
  3. crawford
    crawford New Member
    Is this a pretty decent train. Would like to know its pros and cons.
  4. msowsun
    msowsun Member
    The Bachmann 2-6-0 is really an 0-6-0 switcher with a tiny pilot truck added to it and a different tender. Older Bachmann engines didn't run very well and I doubt this new Bachmann "Standard" does any better.
    I would go with an IHC 2-6-0 Mogul. It will run better and have more detail.
  5. MilesWestern
    MilesWestern Active Member
    AS would I. It's a great locomotive that pulls well. The IHC mogul is about $60, or less, and it;s worth it.
  6. nkp174
    nkp174 Active Member
    Ditto. I love IHC's mogul. It's actually based on a Southern Pacific class of moguls (several survive today).
    It runs smoothly and quietly. It can pull well enough. The engine is well detailed.
    I would avoid Bachmann's standard line mogul, prairie (2-6-2), and mikado (2-8-2)...all of them are made by just sliding extra wheels under other engines. On the other hand, the Spectrum engines are great.
  7. msowsun
    msowsun Member
    There is a company in Brazil that makes a couple of nice little engines that would look great on a logging layout.. They have the drive systen in the tender but I have heard that they run quite well.
    Model Power imported these for awhile. You may be able to find one at a good price
