I managed to get some crappy pictures of the F45's and some pics of the MRC 1806 (for Kato SD40-2) Sound decoder installed. You must use liberal amounts of Kapton tape under it and add solder to the pickup pads (for better connection) and you need to file down (narrow) the wide center of the decoder (where you see the kapton tape sticking up) also desolder and solder the motor pickups from the Athearn board to the MRC board and when installed the decoder os backwards so you need to set CV29 to 007 for reverse operation. Works well and sound is pretty good.
And here are the locos.
Mike
Mike
