another Rocinante build
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
well, i got one of the four that i've been building done.
here is my build of the Rocinante by Michel Grosberg. and of course i have to make it bigger.i did not take enough pic's of the whole build ( i forget things.. i know , shame on me..) but i got enough to share for all to know the fun of this build. his directions are really easy to follow and i like how you build it in small sections. the interior frame work help keep it strong and straight . first off it the engine section. had a small problem withe the inner wall of the engine. was about 1/2 inch short. problem fixed by printing another part and adding the missing section then everything lined up.20180526_111115.JPG 20180526_111220.JPG 20180602_164552.JPGall better
here is the complected section20180602_164544.JPG 20180602_164617.JPG MSGR_PHOTO_FOR_UPLOAD_1528589730458.jpg_1528589732314.JPG
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
section 2 went together easy. made frame work and add outer skin20180602_164631.JPG oh, yea. forgot to tell ya that i i glued the printed frame work to a old cereal box to "beef" it up some. 20180603_153122.JPG here is the skin cut, folded and other parts added. i missed a lot of pics missed
20180603_162852.JPG test fit and a measurement20180603_162911.JPG MSGR_PHOTO_FOR_UPLOAD_1528589997608.jpg_1528589999563 (1).JPG
9,932
I have had a few moments like that. :Computer::headbange: There were a few times where I had to just walk away from the project and take a break for awhile, then approach it with a fresh mind and eyes. :Coffee:
KEEP UP THE GREAT WORK!!!thumbsupthumbsupthumbsup
Reactions: lyter1958
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
it took me a month to build. working on the weekends and getting a few hours in during the week. but she is done (except the stand )20180704_113519.jpg last pic of a old fart holding his baby:):)
9,932
You did a GREAT JOB! It is bigger than I thought. For some reason, I thought that it was about a 10th that size.
If you have "Q-Tip" with paper shafts (which are thicker than most toothpick), you can use them for "gun barrels" or tubes as needed. I use them anywhere I can.
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
well crapp, i didnt think of using q-tips....:hammerhead::hammerhead:. thanks for the "tip".... it is bigger cause i print them out on 11 x 17 paper. easer for me to work with, plus i think they look better bigger:):)
Reactions: Rhaven Blaack
9,558
What an excellent build. The inside framing was a great idea. When you can post a picture that big, and the model looks that good, you know you have really done an excellent job! Superb build! Thanks for posting your work, a pleasure to see. :)
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
The framing is part of the model sheets. With out it, it wouldn't stand up, even in a smaller size. I would love to see plans for other ships from " The Expanse " . this was a real fun build.
Thanks all for looking and the comments. . Now on to "try" to finish the others sitting on the workbench:hammerhead::rolllaughing:
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
I just printed it out on 1117 paper and hit fit to page. I never realy check to see on how much it's scaled up. I'll have to check it out..
9,558
I like the size of this model a lot. :)
