Around 1900 the Wabash rr. owned a second 16 wheel flat car similar to the heavy load flat car #20006 with a load capacity of 55 tons and with other small differences with regard to the construction. Unfortunately there were no more details available so I built the same model like the #20006 with an other heavy machinery part.
I owned this shaft with a maltese crossed wheel from an old mechanically measure device for compressed air and gases with an endless printer. Because this maltese cross you will be able to perform a permanent rotation to a stepwise rotation so that a printing cylinder turns only with small steps for few seconds or minutes. I´m not sure if such a shaft could be needed everywhere in an industry plant. I guess that such huge dimension could
be problematically. However I think that is a good looking load and I mounted additionally two different gear wheels to this shaft. The spoked wheel was built by me too. In detail I used a simple toothed disk wheel as basis for the spoked wheel and I love it each time, with such small changes a very simple part to a correct model part for my model railway to transform.
This model has got Wabash rr. no. #20008 and I hope this has been a good choice.
Finally I weathered and aged this car with chalks like all my other models.
Bernhard
Bernhard
