6 axle athearn sd-40-2 keeps on derailing
matt fisher
48
turlock,ca
same problems
hi everyone
i to just bought a athern gp40-2 blue box and the front truck makes a noise that's sounds like running one truck is off the track ,but it was on track and when i run it back wards it runs quite , but when i run forward it makes that nosie again i just what throw it at the wall but i have'nt done that yet. i took a look at the gears and lubed them and it still makes that noise , what should i do ? athern is now using plastic worm gears instead of brass , has anyone noticed that ? also athern quite makeing metal handrails i hate plastic handrails dont you. if you athern they will send you the replacement parts just give them a call
matt fisher
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
matt fisher said:
hi everyone
Dissassemble the entire truck, if you haven't already (you need to open up the truck tower). check everything, and move them with your fingers and see if you feel any binding. Clean everything off, then re-lube.when you reassemble everything, make sure its all fit together properly. It sounds to me like something isn't sitting right.
the plastic absorbs the sound better.
matt fisher
Why would you wan't to get rrid of the plastic handrails? the athearn Plastic handrails are much better than the metal once in terms of accuracy, and they are more flexible. The metal hand rails rust, get kinked, and can be hard to install. They don't look realistic either. their only advantage is that they are more durable, but with normal handling, plastic handrails should be able to last.
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
alexander said:
For one thing, i think that the noise that Athearn locos make is what makes it an Athearn
Another thing, the Metal handrails are OK, not great, but OK, considering how much time i spent on my Atlas SD24 with the handrails
did you make your own metal handrails? couldn't you just get plastic onces?
