12" radius
Discussion in 'N / Z Scale Model Trains' started by csxengineer, Nov 15, 2005.
  1. csxengineer
    csxengineer Member
    A layout that I am planning has a 12" radius minimum curve on double track. What is the largest diesel and freight cars / passenger cars you would run? Thanks.
  2. tillsbury
    tillsbury Member
    Just about everything will run, with the exception of enormous steam big boys possibly. What you'll have to be careful of is extra-long passenger and freight (autoracks, TOFCs etc). They'll need longer truck-mounted couplers to make sure everything stays connected, and most importantly you need to make sure there's clearance between the tracks -- the usual 1 - 1.25 inch won't be enough, it'll clobber stuff going past on the other track...
