Building UHU's Endurance- My First Build Thread
xpsg
15
8
Singapore
papercraft.xp.sg
Interstellar earned a spectacular 5 academy award nominations this morning! I personally thought it deserved a nom for best picture as well, but I'm completely perplexed as to how it didn't get nominated for best cinematography, seeing as how it was considered by many a frontrunner to win that one.
Anyways, I've finally completed the final docking port! The finished ring measures a whopping 13.5 inches across (not quite as big as expected, but certainly big enough)
Up next, I plan to start working on the central docking hub. I have an idea for a stand for the model. It will have 4 posts of different heights, each of which will have an angled "hand" piece for one of the modules of the ship to sit on. This will hopefully display it at a nice angle AND in a way that I can rotate it to also show the backside, as there is a lot of detail work there.
Without further ado, here are the build pics:
View attachment 139753 View attachment 139754 View attachment 139755 View attachment 139756 View attachment 139757 View attachment 139758 View attachment 139760 View attachment 139761
I hate to be raining on your parade :( but I just noticed that you might have glued "luggage compartments" of the habitat modules wrongly (it's upside-down)
Reference: http://uhu02.way-nifty.com/.shared/image.html?/photos/uncategorized/2014/12/03/31.jpg
Cforrest900
Reactions: xpsg
Cforrest900
Work begins on the final stages of the model: the Lander and the Ranger. As these were the trickiest bits of the model for me, I'm gonna go SUPER detailed on my build pics/ descriptions so that others who choose to build this model in the future may use them as a ref.
To begin with, all parts are cut out and folded:
I then layer the areas where the magnets will go with two extra layers of paper:
For the ranger, I cut out tabs from the 3rd layer to ensure that they will not be visible in the finished product.
Next, I glue the magnets to the approximate area:
As can be seen above, I use a few other magnets to then line up the glued one correctly:
Next: lots and lots of waiting. But in the meantime, I'll begin work on the "wing" for the Ranger
9,894
It is really coming together beautifully!
I am glad to see that you took into consideration that the magnets would put extra strain on the paper and have compensated for it.
Reactions: Cforrest900
Cforrest900
Building the Ranger's wing:
To begin with, I double up some of the areas of the wing. This is to prevent it from warping when glued to the main hull of the ship. I then cut out the shape with the tabs on the bottom layer, which will create something like a butt-joint.
Next, I cut out 1 set of the other 2 pieces to finish the wings. I cut tabs here, as these will become the bottom layer:
The y are then glued into the wing:
I then cut out another set of the "U: shaped pieces with NO tabs sand glue them over the others:
I then take an extra copy of the Ranger hull and cut out the grey triangles for the wing placement from the front half of the hull. I make sure to cut them WITH tabs:
They are then glued into the wings. Note that the front does not line up completely with the front of the wing:
Finally, the top edges are glued, completing the wing:
Up next (tomorrow): completing the Ranger!
9,894
I know that UHU02's models can be (and sometimes are) quite challenging (which is one of the many reasons why I am so drawn to his work in the first place). So seeing what you are doing, I have to commend you on the meticulous care and effort that you are putting into building this model. Such efforts are (INDEED) paying off.
9,549
I am so impressed by how perfect you made this model. These huge pictures would show any defects, and the bigger the pic, the better the model looks! I see a Model of the Month, I guarantee, when finished, a "Model of the Month", to be soon renamed something a bit shorter! (well, not "Something a bit sorter", a shorter title......HehHehHeh) :)
Reactions: Revell-Fan
Cforrest900
:jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::):):)
Cforrest900
The second Ranger is finished:
To begin with, I attach the tabs to the bottom of the hull and cut out the top pieces. Nothing special is done here:
Next, I cut out tabs from a scrap piece of paper to place in the rear half of the hull:
I then attach the upper halves of the hull to the bottom, but do not yet seal the two halves together:
Next, glue is applied to the tabs on the rear half of the wing and it is glued onto the Ranger:
Finally, I seal the two halves together, completing the Ranger:
Up next, I'll start work on the second Lander!
Thanks to all for watching and for the kind words.
Cforrest900
Work continues with the assembly of the second lander's main hull.
To begin, I seal the front of the hull. I would strongly advise scoring these areas, as the folds here are rather complex:
Next, I cut out and install the divider/ support piece between the two sections of the hull. I would not recommend sealing the front of the hull yet, as that makes attaching the central piece of the bottom much trickier.
I then attach the bottom of the central hull and connect it to the front:
Next, I cut out and install the bottom of the cockpit:
Lastly (for this post, at least), I cut out and install tabs at the rear of the hull:
Up next: finishing the hull's rear and finished pictures of the lander's main hull
Cforrest900
More progress: The front pods (possibly secondary engines?) are done.
I begin by cutting out the part with a LOT of tabs:
Next, I fold on all of the lines except for some of the thin grey ones:
The part is then assembled:
Next, you'll need:
A dragon's right big toenail, the blood of a virgin (fresh or store-bought), 1/19th of a unicorn's horn, the 43rd page of an overly-long, convoluted fantasy novel (preferably one with a pretentious name), and a goat hoof. Combine all of these ingredients and then drop the first engine pod in. When the smoke clears, you'll have two:
Finally, the pods are attached to the front of the ship:
