"khaaaaan!" The Wrath of Khan - A mini face-off!
12,419
Very nice! :) Thank you for pointing out the neck issue. The lady was designed for space. So if a support doesn't help, shoot her up and everything will straighten out by itself. ;)
9,571
I really like that scale. Could you imagine a darkened room, with some big ships, and these little ones lit up, it would give such a large impression of scale!! :)
Reactions: spaceagent-9
THE DC
Highly Esteemed Member
I wanted to suggest to use the battle damage on the 1/700 scale Enterprise which is in the archive here
However the shapes of the outer hull do not match. You could rescale page 11, print it on regular paper and transplant the damage to the small one. ;)
Thanks for sharing! Real nice sets!
Any word on the other project; to do the Blockade Runner in a larger scale?
Chuffy70
842
1,709
Norwich UK
On we boldly go with the Reliant...
Parts.
Main Hull is constructed similar to a clam shell by the looks of things
Top and bottom saucer parts, with blank inserts, much the same as the Enterprise
Top and bottom discs formed with greeblies
Discs added to the bottom of the saucer, you can see here they share the same construction on the lower section
Starting with the back of the saucer section at the moment, before seeing how it all fit together
Bridge next up, exactly the same as Enterprise
Hopefully, some different parts to come next
