Tie Bomber design and building thread
mijob
Tie designer
3,241
5,479
95
Netherlands
That looks REALLY GOOD!
Are the rings around the main body supposed to be raised or recessed?
Thanks RB.
Hhhmmm thats a nice suggestion I will look into that. I think I can raise them deppending on how wide the rings are. Also I need to keep an eye on the details on the duselage. So maybe I can make some cutted ring parts to fit between the details. It will make a huge difference. Thanks again for the suggestion.
Reactions: Awry_Chaos
mijob
Tie designer
3,241
5,479
95
Netherlands
I worked on the recessed rings. I cut the line on the fuselage between the rings, and it makes a huge difference. I will change the template. I attached an image I hope you can see the recessed lines.
Again thanks RB for the suggestion.
And this means more work for RF. :animated:
9,592
This is probably one of the best Star Wars models I've seen. It's definitely in the top echelon of models. :)
9,592
Thank You! Seeing this come together is a great thread. It's a model, model build thread! :)
