(MK-I) Colonial Viper ("HELLO KITTY" livery)
9,998
Here is the engine block. As mentioned earlier, I had printed each parts sheet three times. I used the extra end pieces of the main body of the engine block to make internal formers. I greebled the backend by layering the printed texture
Please stay tuned to your local Colonial Broadcast Network for further updates as they come in.
9,998
Here are the parts for the cockpit canopy.
I laminated the main part of the canopy to a sticky label. Then laminated that to a piece of clear plastic.
I also raised the detailed pieces of the canopy brace.
The canopy and brace are attached (No, the canopy will not be functional).
The canopy and brace are attached in place.
9,998
Moving on to the Tail and Wings.
Here are the parts for the tail and wings.
Starting with the guns.
The guns are done. I greebled the textures.
The tail is assembled and greebled.
The first wing is assembled and greebled.
The both wings and tail are finished.
9,998
I apologize for the long wait between updates. However, greebling does indeed take time (especially when you are working with a multitude of very small parts that are difficult and tedious to work with). Such are the greebles of the three engines.
Here are the parts for all three engines.
Starting with the air intake. I raised the turbine blades and "domed" the center piece.
Moving on to the exhaust. I raised the components, inside.
I raised the ribs that go around it.
Moving on to the main body of the engine.
I attached the intake and the exhaust. The engine is complete
All three engines are complete.
The wings are attached to the engines and the engines are attached in place.
