My friend @ASC Mclaren decided to throw me a challenge. To build Crichton in 1:50 scale. So, I decided to pick up the gauntlet and accept the challenge. With the help of my other friend (and the original designer of the template) @Revell-Fan (be resizing the template to 1:50 scale), I built Crichton.
Here is the template. I printed it in 0.22 mm cardstock.
With this template, you have the option to build it "gray" or you can print it on metallic cardstock.
Starting with the base.
Here is the main part of the body.
The body and base are attached.
I attached the two arch pieces that connect to both the base and the body. I also attached the two pieces that go under the arms.
