1/12 Apollo Command Module
Ponytail2
111
38
23
Impressive model... One day...
As for the paper thickness I mostly use 160gr/m2 or 220gr/m2. Last for bigger models.
Never a big issue: who can fold exact at 0.07mm.
Papermodelling has a build-in correction bandwidth, this way.
Reactions: micahrogers
9,592
You score that backside with a blade. ;)
bigpetr
Designer/Master Modeler
Jan 27, 2016
924
1,468
Czech Republic
Hi Toutenkarton, 100lb = 271gsm is for cover paper. For offset/print/book paper it is 100lb = 165gsm. So both is possible
9,592
Did you make contact with Ken L. West? I am assuming you did? :)
the mole
53
40
21
West Frankfort, IL U.S.A.
The rivet looks pretty good. If you don't mind me asking what did you use for the rivet effect?
It's nice to see you have started this project. I can see already you are giving it a lot of thought.
I feel this is going to be a build thread to keep our eyes on and I'm sure I will learn from it.
Thanks.
Reactions: Kolokolnikov
Kolokolnikov
240
1,060
Almaty, Kazakhstan
Thanks.
I am going to make them from bga soldering balls. I wanted to buy them for a long time, and I bought them in a store with electronic components. They are not very expensive for a bottle with 25 000 balls, I paid a little more than 3$
They come in various sizes from 0.2mm to 0.76mm. I have 0.65. The 0.2 balls are very small and very difficult to distinguish in the bottle.
In order for the ball to become a rivet, I simply press it into the cutting mat using a flat metal object. The ball pushes the mat and flattens itself on one side, resulting in a rivet-like shape.
