Klingon Vor´cha Build
spaceagent-9
Right Hand Man and Confidant
3,121
3,489
143
pheonix
I'm thinking of a bright green like in the episodes where Worf is fighting on the side of the KDF with his brother. but i still like my idea of grey with green energy emitters.
Reactions: AdmiralGR
D-WHALE
Utopia Planitia Engineer
Aug 25, 2007
485
405
Schwedt/Oder, Germany
As i started i also used pens, but the color (until it is now a black line) never fit to the surface! then i saw that people using wet colors!
I used a school paintbox with 24 colors and if the color not match, then you can mix with others!
I know that some people are using aquarell watercolor paint, but they are very expensive!
Maybe you will try it for the Disruptor modul?
Reactions: mijob and AdmiralGR
AdmiralGR
405
1,660
London
I might try that. I'm sure the kids have a set!
Reactions: D-WHALE
THE DC
Highly Esteemed Member
I have always used colored pencils but am willing to learn a new thing.
What are these?
Also, where can this weathered paint version be found? I like the DS-9 version as much as the Next Gen you originally did.
Reactions: spaceagent-9
spaceagent-9
3,121
3,489
143
pheonix
I have noticed that some people use black or grey pencils and that at least covers the white paper edge. watercolor pens seem popular.
[ I myself don't use them as I am mostly building tests for modifications. If I were building a show piece I would most definitely buy an extensive set of prismacolor pencils to match with.]
12,467
If I paint the edges and can't find a matching pen I prefer water colours. The trick is not to apply it too wet and only on the edges. The best way to do so is to dry-brush the egdes. That gives you full control of the tone. Load the brush and then "scrape" the colour off onto the edges. You may even dab the paint on. Do whatever works best for you. :)
