And for my next creation....
Cybergrinder
Member Extraordinaire
Jun 24, 2014
2,384
3,992
Johannesburg, South Africa
What I have been doing is working on the top section of the secondary hull so I can figure out the alignment & cuts required for the supports & wiring. Pic coming soon! Then I'll greeble the bottom section (not much on the top)
After that I'll join the nacelles....
Going to need more clear LED's for the saucer.... :)
9,568
Those formers aren't glued down in that pic, are they? Also, in real aircraft, to make formers stick to compound surfaces, the binding agent is a very thick, think, "thick peanut butter, no nuts" as gooped on around an inch thick and wide. This holds the composite surface to the formers, and takes up any difference in shape. Think compound curve saucer, straight edged top of former. Put some longitudinal formers to make the framework even on both sides. You will have a very strong saucer section. Looking really good. ;)
9,568
You are really putting your Cyber nose to the Grind stone!! ;)
Reactions: Cybergrinder
