I wonder if it would match UHU02 TIE Interceptor?
You only have to make sure the size of the eye ball matches to have both in the same scale.I wonder if it would match UHU02 TIE Interceptor?
Since all TIE fighters are virtually identical it should not be too difficult to produce an interior using UHU's files.
Wow. I thought it was about 1/50. I have the Bandai TIE Interceptor and will compare the wing sizes.Uhu02 Tie-interceptor is aproximately 1:70 scale acording to my calculations
Since both Shunichi Makino and UHU02 work together on different projects ...
That is easy enough to do. I may end up doing such .I thought so, too. You would only have to adjust the wing struts and use Makino's hexagonal wings.
