Pepakura Boolean nonsense
Kairu
9
11
I’ll add a picture of what I’m talking about once I get my laptop charged up again, but I’ll ask in case anyone else has noticed this.
But I’ve noticed that quite often I’ll run a Boolean modifier on my blender designs, and once I export the file and open in pepakura as a .obj, a lot of the time the cut portion will partially fill itself in and I have a heck of a time cutting and pasting edges because of a random series of edges the program creates.
Anyone else run into this? Is it a problem with the .obj conversion? A blender issue? Or the dialogue boxes that pop up when you import a file?
Reactions: mijob
Does this happen when you intersect faces? Maybe there is a residual face of the shape you used to cut the main shape. This should be deleted before exporting.
Reactions: Kairu
That would make sense. I always hide the operand after the cut to check for any extra or missing faces, but sometimes blender adds vertices and faces to my operand that I have to go in to fix, so maybe it’s trying to do the same to the cut object. Thanks!!
