Colonial MedSled - 1/18 scale
12,847
Revising the plans for the Power Sled I noticed that the numbering is a bit inconsistent. This is due to the fact that this model was based on the previous version of the Power Sled which in turn was based on the Landram. For this reason the undercarriage assembly starts with numbers "34" and "35" instead of "1" and "2", a few numbers do not appear at all and some are double. The parts are easily identifiable though so you won't have a problem following the instructions and picking the right parts. However, I may revise the numbering at a later date. This has low priority but may happen after the revision of the Landram. ;)
