ZEALOT PHOTO SCALE STALL
9,888
Hello Ladies and gentlemen,
As most (if not all) of you know, I have been working on repainting Tirick's figurines (in both BSG (TOS & TNS) and Buck Rogers). With that, I am taking photos of the figurines next to a scale cube.
Recently, while showing the figurines to a friend, I had used a measuring triangle to show just how big it was. While doing so, I got the idea of making scale stall that I could set a figurine in as well as still use it as a larger scale cube as well. So it can be used in both fashions.
I used the pattern of the Zealot Scale Cube (that is in the RESOURCE Section) for the outside of the stall and a white numbered grid on the inside of the stall.
(Thank you @Revell-Fan for your creative help on this project)
Here is the parts sheet.
Here are the separate parts
It is a simple and straight forward assembly.
The stall is finished.
Showing how you can use it for single or multiple figurines.
