Jim Krauzlis
As a break from my Constitution build I decided to try building one of those outstanding little Yuki Yuji warships in 1:700 scale. I didn't want to get too involved in a second build, but I've got to admit these little gems are addictive!
I decided upon the Arleigh Burke, DDG51, because it seemed to be one of the easier builds than the others, particularly as I did not want to contend with at lattice work mast which the others had or the larger ships he offers...it was, after all, just a diversion.
I spent the good part of today, while the blizzard brewed outside, to work on her. I started one earlier, but I soon found I have no where near the skill or technique Yuki has for building these little hulls. I ended up using a bit of laminated card to the base and decks and took a good deal of time to try and get the hull plates to form, based Barry's earlier build on the O H Perry Frigate (I was inspired, in fact, from that beauty, Barry, but obviously your hull looks so much better than mine came out! Guess I'll just have to practice a bit more on the hull construction ).
I found the hardest part was the bow area, being a clipper type bow...I still believe I feel far short of what Yuki has done with his, but at least it doesn't have a gapping hope in the bow. I also discovered from the first attempt that the base was about 5 mm longer than it should be...it could just be the way I build the bow, I really don't know. :? So, after doing a bit of trimming in the middle, I put the hull sides on and then moved on to the main deck. The deck was also a tad long, but to alter this part would have required a major rework somewhere in the middle as there is an extension on the after end that would have to be contended with, and I did not want to get into that sort of thing on this build.
Anyway, I went on, installed the fantail deck and then the transom. Once that was done the building of the houses was fairly straight forward, once you get acquainted with Yuki's construction method of using no tabs, just but joints. Took a while but by the third part on the house I was pretty comfortable with this method.
Well, this is how far I got today...seeing what it took to get this far, I am just amazed at the way Yuki is able to build these little ladies so quickly in some many at once! But, if I do say so myself, this is a nice little model, nicely designed and the fit after the initial problem (again, most likely my not understanding how it went together) everything was right on!
I did a little enhancement of the forward gun and the gatling gun-like phalanx setup forward of the bridge. I don't know how Yuki manages to roll his barrels so small and tight at this scale, but I cheated and used a bit of wire.
This has been a blast so far, but I don't see this as a long term project, not while I have Constitution staring at me. :lol: But it is a great build to try and I wholeheartedly encourage anyone who is willing to experiment with this type of build to try one...they are very addictive once you get going! :lol:
I'll post more once I get further along, but it might be a while inbetween posts on this one. Hope you enjoy these photos!
Cheers!
Jim
Cheers!
Jim
