Your a Redneck PaperModeler if:(?)
Discussion in 'North America' started by Gil, Oct 5, 2005.
  1. Gil
    Gil Active Member
    Hi All,
    With the RPM(S?) being formed I thought it appropriate to start the Foxworthy Memorial Cardmodel Redneck Appelation Disertation (yeah, the last word doesn't start with a "P"). You guys started the original but it went South with the last site, so here goes again:
    You're probably a redneck paper modeler if the word "Budweiser" appears somewhere on your model...,
    Best regards, Gil
  2. Bowdenja
    Bowdenja Active Member
    You're probably a redneck paper modeler if:
    your knife you use to cut out the parts has Case, Buck or Old Henry on it.
  3. possm_23
    possm_23 Guest
    your probably a redneck paper modeler if......
    ur magnifying class is the bottom of a clear beer bottle........
  4. dwgannon
    dwgannon Member
    You're probably a redneck paper modeler if...
    Your beer can doubles for you glue holder.
  5. Darwin
    Darwin Member
    You are probably a redneck paper modeller if
    you ask Nobi "how do you make a helical coil in Rhino" and "what are the best color values for copper?"
  6. Gil
    Gil Active Member
    You might be a redneck if:
    You only select models that are near beer yellow in color so's the splash stains don't show too badly..,
  7. shrike
    shrike Guest
    If you've created cinder block kits to display your car models on
  8. possm_23
    possm_23 Guest
    you might be a redneck paper modeler if.....
    a topless beer can is your tool holder....
  9. Lepercan
    Lepercan Member
    You might be Redneck Paper Modeler if...
    You incorporate dead grass into your dioramas to hide the dog hair shed on it.
  10. Darwin
    Darwin Member
    You are without doubt a redneck when the clumps of doghair are your diorama.
  11. possm_23
    possm_23 Guest
    you might be a RPM if.......
    your idea of a okla quarter is two dimes and a nickle held together with silver duct tape.....
  12. possm_23
    possm_23 Guest
    you just mite be a RPM if.......
    you have to spell out your initials......
  13. dwgannon
    dwgannon Member
    You might be an RPM....
    You use duct tape to laminate two pieces of cardstock....
    You use your truck tire to flatten a sheet of card stock....
  14. Maurice
    Maurice Member
    Sometimes I worry a little about the descendants of the "worthless refuse" - but only sometimes and only a little.
    Most times there's better to do.
    GEEDUBBYA Active Member
    Hahaha Possm,
    I saw that spell out your initials remark .
    Have a good day,
    Greg W. aka GEEDUBBYA (thats GW)
  16. SCEtoAux
    SCEtoAux Member
    You might be an RPM if...
    you use water and flour to make glue and figure 'What the heck, I'll make some biscuits and gravy too.' [​IMG]
  17. possm_23
    possm_23 Guest
    To reconize a RPM.....maybe your are a RPM too!!!!!!!!!!!!!!!!
  18. jlinscheid
    jlinscheid Member
    You just might be a redneck paper modeler if you spend your free time creating reproductions of historic Marlboro cigarette packs for your mother.
  19. possm_23
    possm_23 Guest
    You mite be a redneck paper modeler if........
    your card stock is the empty case of a 24 pack of Bud.....
  20. silverw
    silverw Member
