Yokomo LCG Conversion Kit
Discussion in 'RC Drifting and Setup' started by Peter T Davis, Feb 8, 2006.
  1. Peter T Davis
    Peter T Davis Guy Behind the Curtains
    [​IMG] [​IMG]
    Click image to enlarge.
    LCG Conversion Kit
    For the MR-4TC SD
    Main features:
    • Lowered drivetrain
    - 4.5mm lower than the standard SD
    • New graphite main chassis, upper deck, front and rear shock towers, battery plate
    • Aluminum bulkheads
    - removable upper piece for easy diff access
    • New aluminum motor mount
    • Upper deck positioned lower
    - 7mm lower than standard SD
    - 5mm lower than SD World's Replica
    • Front and rear upper camber links mounted on bulkhead
    prototype shown : production version will not have camber link holes on shock towers
    • New battery tray system
    - compatible with GP3700 and IB3800 cells
    - no filing of the battery slots required
    - prevents batteries from shorting on the chassis
    • New aluminum steering assembly
    - aluminum bellcranks used
    - positioned low for lower cg
    • Aluminum servo mounts
    • Heavy duty suspension arms
    • Rear bumper
    • Anti-roll bars (front:Rayspeed type, rear:upper type)
    • New rear dog bones
  2. chromecarz00
    chromecarz00 Guest
    exactly what i want. how much?
