Yokomo Drift Package front suspension setup problem...
Discussion in 'RC Drifting and Setup' started by Beskone, Jun 8, 2004.
  1. Beskone
    Beskone Guest
    so i know the drift cars sit really low - but using the set screws in the back you can raise that up -
    here's the problem:
    my front isn't very adjustible tho - and i keep thinking i did something wrong.
    even with the set screws in the front all the way up - the front A-Arms don't go all the way down -
    any ideas? when i run on the yoke tires the ride height is fine, but as soon as i slap on my ABS tires (since they are shorter overall than the drift tires) my ride height is suuuuper low like less than 1/8" in front - and i can adjust the back up to compensate, but i can't get the front any higher, and the bottom of the car takes a beating and it hangs on the bottom every once in a while...
    - Brian
  2. RC-Drift.com
    RC-Drift.com Guest
    You'll have to wrench on your shocks dude.
    Take out the INTERNAL spacers from under the piston head (if there are any)
    OR
    Unscrew the bottom eye a turn or two (this will lengthen the shocks)
  3. Beskone
    Beskone Guest
    naaa, i figured it out - i was drunk when i built the front suspension i think
    hahaha!
    i had the shocks mounted in the wrong top and lower holes... went over to the hobby shop and took a look at my buddies, and sure enough - wrong holes - now it's much better, althought i need to adjust one shock a few turns, as it's still a tiny bit lopsided
    gotta move my body mounts down about 3 holes now - looks like a rally car in the front now ;)
    - Brian
  4. Beskone
    Beskone Guest
    funny thing, with the front slammed the way it was, it drifted better...
    now that i fixed it, and running on the yoke tires it's much harder to throw the car into a drift, and it's much harder to keep it in a drift without the car hooking up striaght.
    on abs tires it's not as pronounced, but still harder to keep a drift going, like there is some understeer happening.
    guess i'll have to play with the setup some more until i get it the way i like it.
    - Brian
