Yard Construction
Discussion in 'HO Scale Model Trains' started by Prof1000, Nov 20, 2007.
  1. Prof1000
    Prof1000 New Member
    Hi Any one know how far apart tracks should be when I am building a yard. Thanks.
  2. tetters
    tetters Rail Spiking Fool!
    General rule of thumb for tracks is 2" on center. Some will go a little closer to simulate a busy packed yard. I think Brakie, one of the regulars on this board, has his tracks closer then 2" for this purpose.
  3. Russ Bellinis
    Russ Bellinis Active Member
    The spacing will be determined by how you intend to work the yard and how you uncouple your cars. If you will uncouple your cars automatically with some sort of under track magnets, you can space the tracks a little closer together. If you will be uncoupling manually with your hands or one of the various designs of pick between the couplers, you will need space for your hand to steady the cars in between the tracks. Also you will need a little extra space between the tracks on any curved sections if you have curves in your yard.
  4. 60103
    If you are likely to be picking up cars in the yard, I would make it the width of a large car plus the thickness of your biggest finger, but not less than 2".
