XtrkCAD and crossovers
Discussion in 'Track Planning' started by iis612, Feb 3, 2007.
  1. iis612
    iis612 Member
    I am currently working with Xtrk, and I am having some success, but I need help.
    I recently switched to Windows Vista, and it disabled the help section for Xtrk.:curse:
    How do I add crossovers on a double main line?
    I have tried using a turnout and modifying it, but it won't join the running end of the second line with the back of the turnout section.
  2. bigsteel
    bigsteel Call me Mr.Tinkertrain
    if you actually have some cross overs or go to your LHS and get all the measurements of the crossover you want ,then go back to xtrk and click 'turnouts' and click on new then go to crossovers,there you can put those measurements to make a cross over.it took me awhile also to figure this out that for some reason xtrk didnt have atlas C83 or crossovers,which is a real pain since my layout has alot of them.anyway hope this helps.
  3. Nomad
    Nomad Active Member
    IIs, if you layed out your track seperation using paralell, there should be no problem making a crossover with # 4 or 6 mark three switches. Snap switches won't work
  4. BigJim
    BigJim Member
    Try connecting two turnouts at the diverging leg then extending the passing legs to get the parallel separation distance for your main lines.
  5. iis612
    iis612 Member
    I ended up joining 2 switches. Thanks for the input.
    I am going to add my crossover sections as per Grewsome's advice and redo it.
  6. iis612
    iis612 Member
    errr....:oops: As per Big Steel's advice
  7. Nomad
    Nomad Active Member
    Hey iss, don't matter, as long as you got it working:thumb: .
