xtm 24.7
Discussion in 'RC General & Getting Started' started by monsterrcbuilder04, May 7, 2004.
Thread Status:
  1. monsterrcbuilder04
    what is the difference between the 24.7 and 24.7 pro?THANX
  2. pimp
    pimp Active Member
    i xtm 24.7 pro has a black crank case and and 6 ports a reg has a silver crank case and 4 ports and the pro has a diffrent carb than the reg and i think a diffrent head
  3. monsterrcbuilder04
    so do you think it is worth the money to buy the pro or should i just get the regular?
  4. pimp
    pimp Active Member
    no the pro and reg is just abot the same the biggest diffrence is the price really the pro is 180 the reg. is 130 and the pro is a tad bit better so i would go with the reg or if u have nothing but money 2 spend and go all out on a motor in xtm go for the pro
  5. monsterrcbuilder04
    no im limited on money so i will just go with the reg.
  6. dj6666969
    dj6666969 Active Member
    well for performense the pro would be ALOT better because it has more ports. More ports means greater power. See if you add more ports to a engine it increses the *flow* of the engine. See that is why some people port and polish there engines all it is really is widing the ports on the sleeve to make the exhaust go out faster. Go for the pro and you can probly find a pro on ebay for the price or a reg 1~
  7. monsterrcbuilder04
    so that would mean it would burn fuel faster, right?
  8. niner
    niner Member
    you can get the regular motor and later on put the pro sleeve and piston in after you wear out that one. it will work fine in the regular.
  9. rcosmax
    rcosmax Member
    the crank is also ported on the pro. They are very different engines and the pro will be much faster/more powerful.
  10. pimp
    pimp Active Member
    it rilly isent that diff. more power but he is looking for something with ok power and high rpm so the reg would be better for 60 bux less
  11. monsterrcbuilder04
    well i really liked the power of the pro but i am hearing it kills the tranny so i probably wont get it
Thread Status:
