X-wing Alliance conversion help needed.
Discussion in 'How Do I...' started by Millenniumfalsehood, Jan 17, 2011.
  1. Millenniumfalsehood
    Okay, I tried installing Fructose's OPT-to-3DS converter, but it said I needed to install X-wing Alliance to run. So I tried installing it on my laptop, the only computer I have that's connected to the internet, and it didn't install; it didn't even try! It just said suggested trying to install the program from the disk, which is what I tried to do in the first place. So I figured I would work around this by using the 3D Object Converter program, which has "OPT" files listed in the types of files it converts, and reading the files directly off the disk, since I can explore it and the ship files are all individually listed in the file called "FLIGHTMODELS", but it keeps telling me "Unrecognized or unsupported file type! (or no valid object found!)".
  2. blaar
    blaar Member
    Problem solved ? :)
  3. Millenniumfalsehood
    I'll let you know as soon as I get home (I've got a 12-hour shift tonight which lasts till 6, after which I sleep, then go to classes; not my idea of fun, but at least I can paper model at the office. :thumb:)
