WWII M1A1 Thompson smg
Discussion in 'Gallery & Designs' started by Nothing, Oct 28, 2008.
  1. Nothing
    Nothing Longtime Member
    thanks mousemuffins,
    the second textures will probably end up on the second version. messin with mesh change it enough that running back through pep there was a heap of fixin to do. so i am at the point of "leave well enough alone".i am going to work on adressing these things on the second version as there are things that need adjusting anyway.
    darthpinapple it will be at ecardmodels.com when i am done.
  2. Nothing
    heres progress on the 1928 version.
  3. Nothing
    been bangin this around all evening and i got it where i like it now. i got one more thing to do and its off to see what surprises pep has for me!
  4. Stev0
    Stev0 Active Member
    Nothing ... why would you use low res textures????
  5. Nothing
    lack of hi res reference???
  6. Stev0
    Stev0 Active Member
    It's an easy fix. Make your own. The same way you created the meshes from references. You already created the stamped designs, just re-adjust your 2D software for 300dpi. It's gonna slow down the machine but as long as you have everything in position you just switch and there you go.
  7. sjsquirrel
    sjsquirrel Member
    Way too cool
    Hey nothing,
    Look what I made myself for halloween. We we're at a halloween wedding where the theme was "mobsters and movie stars".
    I decided to make one out of unprocessed paper fibre (aka wood). Turned out pretty good I think. I made the whole thing working an hour or two a day, in 7 days. The drum is a large coffee-mate container, so it's actually mostly paper. I cut the middle out and then joined the top and bottom back together, and wrapped it in a layer of poster board to smooth it out. It's not highly detailed, but I'm darn proud of it anyway.
    I plan on making a standard magazine and different grip for the front so I can convert back and forth between that gangster and military versions as the mood strikes me.
    Keep up the great work partner,
  8. Nothing
    thats awsome SJ!!!you did a really good job!
    stevo you cant increase the resolution beyond the original image resolution. i dont work with my programs at less than 300 dpi. plus you get degridation increasing the physical size. if i had made the model scale less than 1/1 the textures would be sharper.
  9. Stev0
    Stev0 Active Member
    *scratches head*
  10. cgutzmer
    cgutzmer Guest
  11. johnflys2
    johnflys2 Member
    Well done. Can't wait for the Luger.
  12. Nothing
    thanks Chris!:)
  13. Mousemuffins1
    Mousemuffins1 Member
    WOOT!! just ordered. Didn't get a download link, though. Maybe there's a delay.
    oh, while I think of it, can I ask how you measure the original gun? do you have a sample to copy, use plans or just extrapolate from illustrations?
  14. Nothing
    when i dont have plans i find a good side picture to get the proportions right. then find the dimensions of the real thing and scale it in pep. in this instance the given length was 852mm.
    i cant wait to see what you do with this one!!
  15. Mousemuffins1
    thanks for that. I'll get stuck in shortly, but i kinda promised someone a pulse rifle....
  16. Mousemuffins1
    okay! arrived and started planning/ laminating. this is going to be fun...
  17. Nothing
  18. Nothing
    working on it. i am really fond of the luger so i will be pushing my sanity on it.it will take some time to pull it together.;)
  19. Major Walter Schmidt
    Major Walter Schmidt Newbie Designer
    Maybe you can make artillery versions... Better yet, print it on gold paper and make a Goring Luger!
  20. DHL
    DHL Member
    It looks great
