Okay, a few roadbed questions!
I recently got all my Snap-Track together and laid it out in a plan I like. Then I put the Woodland Scenics foam roadbed underneath, just to see how it would look.
I think it will look great when it's done. But first, there are those pesky questions...
To start, I should mark the track, pull it up, and place the roadbed where the track will go, correct? I'm just afraid I'll glue the roadbed down and it won't match where the track is going...
Can I use Elmer's white glue to glue the foam to the homasote base? Or is Elmer's not foam-friendly? What about gluing the tracks to the roadbed?
How do I avoid kinks in the turns? Should I split the roadbed in half, and stagger it throughout the corners?
Should I extend the foam so that it goes under the switch box on Atlas Snap-Switches... (Hehe, I think that's a no-brainer... )
Some of you don't elevate your sidings and yards, right? So how do you transition from the elevated roadbed to the sub-roadbed? (In my case: homasote.)
Thanks. Pretty soon, if I get this done, I'll have some ballast questions... :thumb:
P.S. After seeing what's been going on here at the gauge, with all us "noobs", I just want to sincerly apoligize for coming in. It sounds like you all were a little, tight-knit group of modelers, and we came in and spoiled that. I'm sorry, but your advice and expertise is desperately needed... so share! (Just kidding, just kidding...)
