I heard that if you spray the wood peices on these with dullcoat before assembly, it prevents warping. Anyone ever heard of this method? Do you spray both sides, or just one side?
Does the anti-warp sealer affect staining?
Sealing the wood first would prevent it from soaking up the stain, and providing better control on the depth of color. No different than for furniture. Just one thing, there is a difference between a wood sealer and a clear coat finish. Always stain before you apply a finish coat.Originally posted by sumpter250
Yes. you would have to procede much the same way you would with styrene, after sealing the wood. Staining first, and sealing with dullcote sounds like the right way to go, if you want a stained finish.
Pete
Originally posted by grlakeslogger
And, for what it's worth, I stopped using Dull-Cote about a year ago. I've replaced it with Testors Model Master Clear Flat Lusterless spray finish. I believe the number is 1960. Jeff Wilson said the same thing in a freight car weathering clinic I heard him give a month ago.
Good luck.
--Stu--
