Wiring turnouts/switches
Nick8564
141
I am just starting to use turnouts in my layouts. I only had a simple layout then i had to take it all down. I need to know how to wire my turnouts to the switch and the switch to the power. Thanks for helping.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Nick: I assume you're asking about the switch machine wiring, not the track. I'll also assume you have a Snap-Switch type and a little electrical switch that you slide and then push.
There are 3 screws on the switch machine. One is a "common" and goes to one of the AC terminals on your power pack. You can connect all the commons together to a single wire. There is also a common screw on the electrical switch. This gets connected to the other AC terminal. There are two more screws on each unit; these get connected together by two wires. Then you try the controller. If the switch goes the wrong way, reverse the last two wires.
