Wiring 2 way motor on remote...
Discussion in 'RC General & Getting Started' started by kyo, Oct 27, 2003.
Thread Status:
  1. kyo
    kyo New Member
    Trying to rig a low speed motor to turn both directions, which is controlled with a remote.
    Looking to keep it small obviously..
    Any ideas?
    Thanks,
    Kyle (Kyo)
  2. timrock
    timrock Active Member
    i dont know what the #@$% your project is but to make the motor run both ways you simply trade the + for the - to oppose the one direction.
  3. timrock
    all i said was what the heck your...
  4. timrock
    wire two switches to the motor.one switch, wire one way and the other the opposite way. (the opposite polarity)(+ and -)(red and black wires)then mount the servo to turn one switch on so that you can turn it on when you pull the triger on the Transmiter (`remote``).or when you push the stick forward ,wich ever kind you have.and have the switch turn off when you let go of it.you will need what are called Momentary ,Push button switches.and just do the same for the other switch to turn the motor the opposite way.so that when you pull back the stick or push the trigger back.depending on witch kind of a `remote` you have.
    any questions just ask.
Thread Status:
