Hi, Erick!
Well, is the nylon thread made up of many strands or is it a single thread like fishing line? If it is a single thread, that can be a problem if you want to stiffen it. If it is made up of many threads, maybe you could get it to stiffen up by painting it with a light wash of paint the color you eventually want the rigging to be. Just go easy on the wash so as not to add too much thickness to the finished thread. I like to use PVA to lightly saturate the string and get it stiff, which makes it easier to take out the slack and reduce the any fuzz that the string might have. I usually put a little clip on each end of the line so that after I finish saturating it with the glue I can then hang it from the edge of my work area and let it dry using gravity to keep the line straight until the glue or paint dries.
You can't get that CA on your end? Crazy Glue, or similar products? That's okay, I used white glue (PVA) for most of my modeling as I don't like the way CA leaves a shine after it dries, and the fumes are pretty offensive and harmful if you're not careful to work in a well ventilated area.
A bit of pre-planning is good for rigging, particularly if you have lines originating from a spot on deck or the funnels where it's going to be a bit difficult to add them...but you can still do it by putting a small hole in the first spot and gluing a length of thread with a knot into the hole. Let it dry very well and then run it to the next point. Here you'll have to try and thread a loop in the string into the hole using a pin, point of a toothpick or the like. I like to put a small dab of PVA in the hole first so the small loop of thread goes into the glue and sticks a bit rather than just fall right out...and be sure to push the loop in so as to take out the slack in your line that goes down to the first glued point. Once you have it as tight as you like, put another dab over the thread in the hole and let it dry. When thoroughly dry CAREFULLY trim the excess end (the part that is not your rigging ) as close to the hole as you can...be careful not to slice the other line which you want to leave for the rigging in the process... a very sharp blade or razor works well, just be careful!
Just some thoughts which I hope help.
Cheers!
Jim
Cheers!
Jim
