Well, it's been a while ... quite a while, actually,... but, being New Year and all, I figured it was time to get back to my Constitution.
Actually, I have been looking up the rigging plan, just to be sure before I got into the masting and rigging. For now, however, I need to finish up the hammock nettings and the mizzen fife rail, before moving into the channels and masting.
So, I am continuing with the hammock netting. You might recall I was using a silk scarf I found in the Big Apple at a small Kiosk close to where I used to work. After finishing the port side forward netting I figured there was a quicker way to put the netting together.
I decided to use a wax paper covered card on which I drew parallel lines that matched the height of the finished netting. I also soaks some fly tying silk thread with PVA, which I used for the top and bottom lines of the netting. Here's a photo of the card set up with the netting in place with the glue soaked line on top and in place:
I also used some fine annealed steel wire for the hammock irons, just a matter of bending them into the right shape and gluing them to the top of the bulwarks. In this photo you can see the trimmed hammock netting and to the left is one of the hammock irons ready to be installed:
Here's the starboard side forward bulwark with the hammock irons glued in place:
This photo shows the netting glued in place...I thought using a white card would help show the netting better, but it didn't come out as clearly as I planned:
Here's the way it all ended up...I still have to touch up spots here and there, but it's pretty much done:
This view shows how the irons sit on the bulwark with the netting on each side:
And, a final view:
Before I work on the quarterdeck hammock nettings, I need to finish up the mizzen fife rail, otherwise I can expect the netting would be banged around a bit when working in and around the deck area...I hope to show the mizzen fiferail in the next installment.
Thanks for stopping by and having a look...I'll try and keep the delays between updates a bit shorter next time.:grin:
Cheers!
Jim
And, a final view:
Cheers!
Jim
