why dosent my engine start
Discussion in 'RC Onroad Forum' started by alisar70, May 17, 2004.
Thread Status:
  1. alisar70
    alisar70 Member
    ive got a brand new car BUT IT DOSENT START y
    ive checked eveverythink
  2. dj6666969
    dj6666969 Active Member
    maybe the manufactures screwed up( dont really think so tho) umm is fuel getting to the carb? did you do anyting with the needles? With a brand new engine dont mess at all with the needles tell you have it started and are in your break in period
  3. Steve M
    Steve M Member
    What car did you buy? A little description of what you have might help.
    I think you really need to switch to electrics as you just don't seem to have any luck with nitro at all.....LOL
  4. bandit1
    bandit1 Member
    steve, i agree!!
    but anyway, check glow plug battery, check glow plug, check factory settings on ur needle's, check for fuel line for leaks, and make sure ur following the correct starting process. good luck, and dont give up after like 5 minutes, if u've been. stick with it!
  5. pimp
    pimp Active Member
    did u prime it and all check the check the plug and igniter and make sure that fuel is getting 2 the carb
  6. alisar70
    alisar70 Member
    yeah i checked everythink
    it now starts but floods is that usall with new engines
  7. bandit1
    bandit1 Member
    well, it could be way too rich, but make sure if ur fuel cell has a primer, only push that so theres a little bit of fuel in your carb. Also, if it floods, take out your glow plug, and flip over ur car, making sure theres no fuel and try again.
  8. alisar70
    alisar70 Member
    yeah
    thanks
    NOW THE CAR STARTS BUT DOSENT GIVE ANY SMOKE OUT HOW COME??????
    ITS RICH AS IT CAN GET
  9. bandit1
    bandit1 Member
    no smoke=WAY too LEAN. Make sure ur turning the right things, did u break it in yet?? if not, ull want to let it run a little on the rich side.
  10. alisar70
    alisar70 Member
    yeah thanks
    its now quite loud how do i make the noise less louder?
    I MEAN loud!!!!!!
Thread Status:
