Why does my car stall ?
Discussion in 'RC Offroad Forum' started by alisar70, Mar 15, 2004.
Thread Status:
  1. alisar70
    alisar70 Member
    Why the #@$% does my car stall when im reving it fully ive tryed the idle screw but nothing is happening
  2. Did you break it in
  3. alisar70
    alisar70 Member
    Nope i didnt use my brakes and when i do brake It dosent stall
  4. Steve M
    Steve M Member
    You've missed the point that Danny was making altogether.
    When you buy a new nitro motor, it needs a short period of careful running to "break-in" the motor before it operates smoothly and properly. The metal to metal parts inside a motor need to wear just a tiny bit (known as break-in) in order to provide best performance and long life.
    If you took your new motor and ran 25% nitro fule at full throttle right from the box then you have most likely caused stress due to over heating parts. The same basic principles apply when you purchase a full-sized car. You don't just fill up the tank and then drive it full throttle on the highway.
  5. alisar70
    alisar70 Member
    Yes but ive drove It like 4 tanks with half throttle and stuff
    can i now go full throttle
  6. ty007cars
    ty007cars Member
    its too rich!!! lean it down just a little if that dosent work then you need to keep tinkering woth it to get it right.
  7. Steve M
    Steve M Member
    Sounds like your motor has had proper break-in.
  8. alisar70
    alisar70 Member
    So does that mean i have to buy a new motor
  9. Steve M
    Steve M Member
    No....your motor should be all set and ready to deliver its best power now.
  10. alisar70
    alisar70 Member
    ok so now i can fully rev it
Thread Status:
