Why does it Cut off
Discussion in 'RC Offroad Forum' started by alisar70, Mar 14, 2004.
Thread Status:
  1. alisar70
    alisar70 Member
    hi i got a nitro winner sport with a 15cxp engine when i fully rev it it just stals
    Oh and another problam when i switch on my engine it just Wants to go what shall i do [?]
    Ali sar
  2. your needle settings are too lean.....you need to change your needle settings.....turn them counterclockwise and see what that does.......
  3. alisar70
    alisar70 Member
    Im getting confused dude clockwise was <--------- wasnt it
  4. Clockwise is the way the clock moves....look at a clock and the way the the arms move that is clockwise.....counterclockwise would be the other way......
  5. alisar70
    alisar70 Member
    OK so has ANYONE IN THE WORLD NO WHY MY CAR CUTS OFF WHEN IM FULLY REVING IT
  6. jlmoreno911
    jlmoreno911 Member
    Check your fuel filter it might be clogged causing your air to fuel mixter to be too lean...
  7. alisar70
    alisar70 Member
    iM NOT SURE WHAT U MEAN BY FUEL FILTER IS THAT WHERE THE AIT GOES IN?
  8. what grade are you in bud, Did you brak it in yet?
  9. Steve M
    Steve M Member
  10. alisar70
    alisar70 Member
    Okt thanks but ive tryed all of that and it dont work
  11. Steve M
    Steve M Member
    Well, there isn't much more I or anyone else on these forums can do I'm afraid. Nitro powered R/C vehicles are the most difficult of all to get running properly and there are just too many variables to be able to help you.
    Rather than posting your questions here, maybe you should take a drive to your nearest hobby shop with your car and ask for hands-on help.
  12. alisar70
    alisar70 Member
    Ok thanks,... making my car to rich will damage ythe engine is that true
  13. Steve M
    Steve M Member
    Too rich may cause problems but a bit on the rich side is just fine. Too lean will cause excess heat and with that comes friction and finally broken parts.
  14. alisar70
    alisar70 Member
    OK thanks BUT how do i know what to rich is
    Oh and my car is just 1 week old
  15. ty007cars
    ty007cars Member
    too rich is when theres TOO much fuel in the engine which can make it loose power and is very sluggish.
  16. Steve M
    Steve M Member
    When you give full throttle and the motor bogs and slowly builds up RPM, then it is most likely too rich.
    If, on the other hand you give full throttle and the motor revs quickly but then drops off if you hold it at full then you are most likely too lean.
  17. alisar70
    alisar70 Member
    Ok this is what happens I rev it fully And then it revs for like 2 seconds then it cuts off Do i need to make it richer
  18. alisar70
    alisar70 Member
    because its to lean shall i make it richer
  19. Steve M
    Steve M Member
    Make it richer and try again.
  20. alisar70
    alisar70 Member
    Oh 1 more thing Theres Lik all oil on my engine now
Thread Status:
