White Knight
Discussion in 'Internet Finds' started by cecil_severs, Dec 21, 2004.
  1. Hans Christian
    Hans Christian Active Member
    I filled up mine with super glue... :)
  2. jmueller
    jmueller Member
    you can just take the tip and push it slightly with circling motion onto the table. This will close the hole. (Is that a good description... :oops: )
  3. Maurice
    Maurice Member
    Jayo explained once that it's virtually physically impossible to roll a cone properly if the very tip of the wedge is left in place. Jan was simply allowing for this and his suggestion sounds like the perfect solution.
    Thanks for the model Jan.
  4. jrts
    jrts Active Member
    Hi all
    Fantastic model mate, I will get to building this very soon :D
    Thanks for the FREE download.
    I will try to do it in photo paper, the same way I did your gilder.
    For the very small holes at the end of cones I tend to use a small ball of paper soaked in PVA. Then pushed into the hole and then molded to the shape required (before fitting the cone to the model) :roll:.
    It works even better for the rockets that have a rounded tips.
  5. billmcc
    billmcc Member
    Yes, that is a good description of how to close the hole. Thank you.
    Maurice and Rob,
    Thank you for your information and technique.
  6. Hans Christian
    By the way sir, when could we expect your version 2 of WK? :roll:
  7. bholderman
    bholderman Member
    Greetings all,
    Could anyone help me with the username and password for this file. I lost track of it and can seem to locate it anywhere.
  8. rickstef
    rickstef Guest
    it is quite simple, it is the url for our german sister site
